So I am just making my new build and I do not have a new desktop cpu as of now, I have an Intel i5 -8250U( which is a notebook cpu), and I dont know if that will work in my z390. If it doesn't work then what cpu can I get that is compatible and is relatively cheap.
Thanks in advance for any tip/help
https://linustechtips.com/topic/1307351-need-help-with-processor-compatibility/
Is the 8250U in your laptop?
If so, no, you can't remove it. You'll need an 8th gen or 9th gen chip to put in your Z390 board.
What do you want to do with the PC?
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
5 minutes ago, Muqqy said:
My main use for the PC is for gaming, and sometimes for school. I am just starting with not much experience building so what cpu I am looking for?
What resolution and refresh rate, e.g. 1080p 60 FPS, 1440p 144 FPS, etc.?
I haven't thought of that yet. What would you suggest?
Make sure to quote people so they see your replies.
What's your budget?
