Can anyone recommend some good USB desktop hubs? I've found a few, but I'm wondering what some of you guys may use. My case is a 900D and I'd rather keep the front closed, and keep the cables either on my desk or around the back.
I'm looking for something that is going to be pretty sturdy (rubberized feet) and has USB 3.0 functionality on it. It would also be nice if it has an external adapter so it can charge a phone/kindle and I'm looking for more than 4 ports but it can be a combination of USB 2.0/3.0.
So yeah any recommendations?
Thanks.
https://linustechtips.com/topic/130539-desktop-usb-hub/
Please, update your profile with where you are from or actually say so in the post.
Many people just forget to say where they are from....
Its hard to recommend anything when stuff might not be available in your country,
Any Belkin hub will be fine.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/130539-desktop-usb-hub/#findComment-1737801
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
https://linustechtips.com/topic/130539-desktop-usb-hub/#findComment-1738434
