Audio stuffs.
Go to solution Solved by chicksoup,
the interface box is pretty good and playing guitar will work just fine...I'll message my friend for his Monitors, because he got some really good ones for about 200€
Hello people.
So I am planning to buy these monitors.
http://www.thomann.de/fi/maudio_bx5_d2.htm
What would be the best affordable interface for the monitors? First thing that came into my mind was this:
http://www.thomann.de/fi/m_audio_m_track.htm
I'm planning to input my guitar in that. Could I use the monitors through this with my guitar and then play with that? Also, if it is possible, does it have a lot latency? Or should I just use an adapter and then plug it to my computer with that?
Thank you.
Potatoes are good for your nostrils.
https://linustechtips.com/topic/130432-audio-stuffs/
http://www.thomann.de/at/steinberg_ur22.htm
this one looks nicer and on the german website it has a score of 4.7 out of 5 compared to 4.4 that you picked
Yeah I was thinking about getting that one too but my budget is a bit too tight for that. I would love to get that software though. :F
I guess I'll just have to wait for a bit.
https://linustechtips.com/topic/130432-audio-stuffs/#findComment-1736497
what software do you mean? I think when you get the speakers I recommended you and the other DAC you are still spending less than initially
https://linustechtips.com/topic/130432-audio-stuffs/#findComment-1736510
I mean the Cubase that comes with the Steinberg pod. With the M-audio you only get the Ignite which is not the best software. That is what I have heard.
https://linustechtips.com/topic/130432-audio-stuffs/#findComment-1736564
