I have 2 RX580, and a RTX 2070 Super  Usually doing nothing. I have a SFF Dell computer that I can take the motherboard out and use 1x to 16x Express connectors for it. Does anyone know if this is a good idea? I don't want to spend money on a different mobo and CPU. Also does anyone have any recommendations on what 1x to 16x connectors to buy. I don't  want to buy ones that fail later.
https://linustechtips.com/topic/1303356-starting-a-mining-rig/
It depends on what coin you want to mine, as well as how much electricity is near you. Depending on that you may never actually make money.
https://linustechtips.com/topic/1303356-starting-a-mining-rig/#findComment-14463711
If you have the psu to handle it all, then might as well.
https://linustechtips.com/topic/1303356-starting-a-mining-rig/#findComment-14470891
