help no cd drive
Go to solution Solved by Ownster,
i got halo 2 for vista but my new pc have no space for a op. drive and all the sata ports are been block by my gpus .i am searching for a help bcz i dont want to buy one(optical drive) and i dont want to take my gpu off to instal a sata cable...i got a laptop it was a optical drive ...
You could copy the disc with magiciso on another pc and then put the iso on a flashdrive, use magicdisk, and mount the iso and install it that way.
Btw halo 2 for vista, the gwls is shutdown.
https://linustechtips.com/topic/130311-help-no-cd-drive/
https://linustechtips.com/topic/130311-help-no-cd-drive/#findComment-1735078
i think the dedicated server still up and i just wanted the campaing
https://linustechtips.com/topic/130311-help-no-cd-drive/#findComment-1735116
