Shut down PC without power button.
Solved by flibberdipper,
All a power switch does is short the pins. So yes, to shut it down you just short them again. Some boards will do it on contact if you're not in an OS, others will make you hold it for a bit.
michaelb198 ·
Posted in Peripherals1 -
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
Posted in Graphics Cards3 -
11
5
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies4 -
Airmack ·
Posted in Graphics Cards1 -
Kyle89 ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
