Hello lads, my English is not my mother tongue so i hope you understand what i say. So let me get straight to what i wanna say. I recently bought a new CPU cooler and i have put my heatsink ofc in a vertical position so as not to interfere with the RAM sticks. I have put my fan in the left side of the heatsink so that means that the fan is pulling air from the fins and exhausting them to the back of the case, is that how it should be? I am currently watching JayzTwoCents' video about common mistakes when building a computer and he says that the fan should be in the right side (next to the RAM) and it should be in a push config and not as a pull one. Basically push config is the fan takes cool air from the case and blows it straight to the fins and the hot air is on the other side? is that how it is? (don't know how to explain it better). If i have understood it correctly, my fan right now is in a pull config meaning that it takes the hot air from the heatsink and throws it next to the case fan and the case fan exhausts it out of the case, so have i done it wrong? is Jay correct with that he said? If so, then i have to put the fan in the other side (not sure if my fan will fit cuz i have 4 RAM sticks but will look later). I want a small detailed explanation on which side should the fan be and what should it be, either push or pull. Also sorry if i have messed everything up lol, this is quite confusing for me. Thank you!
Edit: The CPU cooler i bought is the Alpenfohn CPU Cooler SELLA and this one specifically as i look at some photos, the fan is placed in the left side
https://linustechtips.com/topic/1302210-cpu-cooler-fan-push-or-pull/
Doesnt matter, heat soak will happen and the temperature will level out regardless.  I mean, maybe a 1-2c difference but Im not saying either way is better (until I personally test it).  Personally I put things in push config if I have 1 fan.  If I have ram clearance issues I put it in pull position, and do not give it a second thought.  If I can I always push/pull.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
If so then i will try it personally and see if there is any difference but first i have to see if i have space to put the fan lol cuz of the RAM, ah well, appreciate your help!
What mobo, if you have 4 dimm slots, and 2 dimms they should be in the 2nd and 4th slot away from the CPU - just looked up the cooler, there should be plenty of room based on my experience (unless this is a 2 DIMM mobo perhaps)
My mobo is a GA-P55M-UD2 and i have indeed 4 DIMM slots and i have 4 RAM sticks installed but pretty sure there should be enough space for it cuz the fan is quite small so yea. I should've listed my PC specs before but i thought no one would need them lol but here we are you asking me what mobo i have lol.
No worries!  For me I wouldnt worry about the fan position on a single mount - you could offset this temp difference (IF there is one, Im not convinced there is due to heat soak) with good thermal paste, like Kryonaut (drops temps by 2-5c in most applications)
Gotcha gotcha. I mean, i will try putting the fan in the other side one day and see if there is a difference at all, if not, then i will put it to where it was but i am very happy with that CPU cooler cuz i OCed my i5-750 from 2.8 to 3.6 and i get max 62c when gaming and 32c when idling which is crazy because before that i had the Intel stock cooler and you know what it was like with that cooler lol. I tested the new cooler ofc without the CPU being OCed and i got 50c max when stress tested and 28c or so when idling which is very impressive for a 27 euros cooler. With the Intel cooler I got 80c in WINTER times lol and in summer, 99c without a doubt but hey, it was not OCed, imagine. Anyways, i will put the fan in the other side and if doesn't make a difference, i will put it to where it was.
Oh also, i used the included thermal paste that the cooler had and it's really good, it's not liquidy so it has like a nice consistency. Fun thing is that the leftover thermal paste has still like 2-3 more uses which i'm really happy.
