Need help. Minecraft Forge Server will not load. (Ubuntu 20.04 Desktop)
Solved by The L2d,
Ok so the problem was fixed, even though this may never see the light of day I do want to provide a fix in case someone on the internet has to fix this later on.
So the fix was as simple as switching to openjdk8, in order to do that you should enter the command sudo update-alternatives --config java just like so into your terminal of choice in linux and selecting 8.0.
Another possible fix was renaming it, although I never seemed to get it right and I'm not sure that was an actual fix.
