a few months back my house upgraded to 1000mps WIFI with xfinity. ever since then I've been having serious network issues. However my pc is the only device in the house that has issues at all. When I'm doing something like playing games , talking in discord or attending classes via zoom my internet disconnects for only a moment before it reconnects right after. If I'm playing a game sometimes I will lose connection to the game but I wont lose connection in my discord call and vise versa. Now I'm also having an issue where none of my Logitech devices are being recognized by the Logitech software. When my computer falls asleep it will restart when I try to wake it up even if its only asleep for  seconds. I have tested each stick of ram individually the problem still happens. I have completely wiped my pc twice and installed a fresh copy of windows each time and the problem still exists. sometimes I wont have a problem for days other times I will disconnect every five minutes. could it be a CPU issue. i have also replaced my network cable ive tried using a second router and restarting the xfinity router nothing has worked
our wired connection
is also 1000mbps
rog strix b450-f gaming II
ryzen 7 3700x
gigabyte aorus rx 5700xt
32gb 3200mhz corsair vengance pro rgb
500gb Samsung 970 evo
850 watt nzxt modular power supply
Xfi advanced Gateway
Its the new one they have its the white wifi 6 router
i tried running some commands that were recommended to me but they didn't fix my problem
https://linustechtips.com/topic/1301895-help-please/
Have you tried a wired connection to the router from your pc? If you do t have a long cable just set up your machine close to the router temporarily. If it’s a WiFi issue it may a channel problem which you can change, that may explain the intermittent dropping, your neighbors may be using their WiFi which causes yours to drop out. I’m not a Network engineer, just trying to suggest something.
R5 3600 4.3Ghz, Asrock X570 Pro4, LPX 3200 4x8Gb, 2x 500Gb WDBlue NVMe, MSI Gtx 1070 Armor
https://pcpartpicker.com/user/ogbt88/saved/QXQRK8
https://linustechtips.com/topic/1301895-help-please/#findComment-14452046
