So my current PC is as follows:
GIGABYTE GA-Z68XP-UD3P LGA 1155 Intel Z68
Intel Core i5-2500K Sandy Bridge Quad-Core 3.3GHz
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin
CORSAIR CX-M Series CX650M 650W 80 PLUS BRONZE
(Old GPU) XFX Radeon R9 380X R9-380X-4255 4GB 256-Bit DDR5
(Replacement GPU) MSI GeForce GTX 1050 Ti DirectX 12 GTX 1050 Ti GAMING X 4G 4GB 128-Bit GDDR5
My PC is old, but worked fine until I replaced the gpu. now it freezes at random, possibly when I touch certain parts of it. I'm not sure. It's frozen when I touched the side of the case, which isn't fully locked into place at the moment, I'm lazy. What I think may be happening is there is a discrepancy because both AMD drivers and nvidia drivers are installed. I tried uninstalling my Radeon graphics the other day and it didn't work, so I'll have to try something else.  None of this happened until I put the new replacment GPU iin. anyway, that's the long and short of it. Thanks for the help in advance.
https://linustechtips.com/topic/1301703-possible-gpu-issue-pc-freezing/
MOBO
CPU
RAM
PSU
Old GPU
w
Replacement GPU
Can you please list it without links?
DDU your drivers (here's a guide: https://www.wagnardsoft.com/content/ddu-guide-tutorial), and then install only the NVIDIA drivers.
This should remove any conflicting driver weirdness.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
I relisted my parts, I think tthat is what you meant. If not I'll check it in the morning. Thanks for the help. I'll try the solution tomorrow.
