Help!
Go to solution Solved by Downkey,
5 minutes ago, Asad0099 said:
Hello 👋. actually I don't have any good idea about pc build.Now I want to build a pc within 1100 dollars pls give me suggestions for best performance
What will you be doing with the PC. If gaming, what resolution and what games are you playing?
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
https://linustechtips.com/topic/1301620-help/
try to be specific what country , whats is expected etc
‘You don’t learn to walk by following rules. You learn by doing, and by falling over.’ –Richard Branson
https://linustechtips.com/topic/1301620-help/#findComment-14449996
geometry is hard
b550 > x570
https://linustechtips.com/topic/1301620-help/#findComment-14450007
1. Do you have a monitor that you can plug in and use?
2. What about other peripherals (keyboard, mouse, audio)?
3. Also what would you like to use the computer for?
hi, im renata bliss and am ur freestyle dance teacher
https://linustechtips.com/topic/1301620-help/#findComment-14450014
I have a monitor already.now I need it programming.cad gaming .
https://linustechtips.com/topic/1301620-help/#findComment-14450026
I am a engineering student.i need for programming .and I also  require to play gta v .cod.
So if your willing to wait for GPU prices to go down, then this would work well.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1301620-help/#findComment-14450027
1 hour ago, 1ppOverheat said:
A Ryzen 3 3100 would be better value. 3000 less and has better gaming performance.
For 1100 a 1660 Super isn’t good.
The H510 is a garbage case with no airflow. Can garuntee that OPS temps will be very high.
Lastly, the PSU is a very poor quality unit. BQs are very mediocre models.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1301620-help/#findComment-14450295
1 hour ago, Downkey said:
1 hour ago, Asad0099 said:
I am from bangladesh.i expected make Good suggest within the amount .also good graphics card with in the amount
Not sure if you saw but this is my list 😄
geometry is hard
b550 > x570
https://linustechtips.com/topic/1301620-help/#findComment-14450297
Crap, you're right. It was late so i wasnt really thinking about it.
https://linustechtips.com/topic/1301620-help/#findComment-14451142
