I have seen this problem before. Did you happen to change anything with your power management settings? This problem was caused by Hybrid Start being enabled last time I encountered it. You can try disabling hybrid start by typing the following into an elevated command prompt:
powercfg.exe -h off
shutdown /p
the shutdown /p will immediately shut down the PC. So make sure you close any work you have open before typing this in.
"Although there's a problem on the horizon; there's no horizon." - K-2SO
https://linustechtips.com/topic/1301361-need-help-please/#findComment-14447946
powercfg.exe -h off
shutdown /p
Thank you I’ll try it when I get to the rig
https://linustechtips.com/topic/1301361-need-help-please/#findComment-14447967
powercfg.exe -h off
shutdown /p
Didn’t work still takes almost a minute to connect to the internet any other ideas
https://linustechtips.com/topic/1301361-need-help-please/#findComment-14448191
