Hi. In July I got my new pc. Then all of a sudden recently I had weird frame drops and stutters. I have down diagnostic tests, virus scans, reset my pc, and have looked at my parts and have seen no damage and have also seen that my parts are healthy and fine, and I have reinstalled the drivers. I play fortnite(low settings, full resolution, directx12). I can’t really think of any problems. The only things I can think of are that cpu overheating, bad power supply, I accidentally turned off the power strip while my pc was on and was not downloading anything. I am planning to clean my computer and getting a cpu cooler. It is just my game that’s weird. My windows is fine. I hope I can get some help.
my specs
b450 asrock steellegend, 650 watt bronze evga, 1660super, crucial 1terabyte, oloy 3600 16g ram, 6fans, 2600 processor with stock cooler, o11 dynamic,
https://linustechtips.com/topic/1301295-sudden-pc-frame-drops/
my specs
drivers. update drivers
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1301295-sudden-pc-frame-drops/#findComment-14447331
3 minutes ago, Zob said:
bruh
oh. lol. I did not see that🤣
Have you tried to lower your settings in those games? Also what do you mean by "full resolution?" 1080p, 1440p?
Also what exact model of EVGA PSU?
https://linustechtips.com/topic/1301295-sudden-pc-frame-drops/#findComment-14447342
7 minutes ago, Zob said:
bruh
I have reinstalled the drivers and updated them
I lowered everything and have a evga 80plus bronze 650 watt power supply and I use 1080 by 1920
https://linustechtips.com/topic/1301295-sudden-pc-frame-drops/#findComment-14447351
I updated drivers and everything. Can it be that the driver update for me was bad and I need to wait for a new one
https://linustechtips.com/topic/1301295-sudden-pc-frame-drops/#findComment-14447355
