So I built my PC not to long ago and I'm kinda running low on space. These are the parts that are in my PC.
Tuf b450 plus gaming motherboard
Amd ryzen 5 2600
Samsung evo 970
16 gb trident neo
Msi geforce gtx 1650
I'm wondering if I can get a hard drive and hook it up and if the parts are compatible. Also would like others suggestions. Thanks
https://linustechtips.com/topic/1300999-building-help/
Everything would work fine just like that, just plug that new hard drive into SATA and format it and you'll be good to go
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/1300999-building-help/#findComment-14444929
