Hi guys,
After turning on my main livingroom system (spec in the sig below) yesterday and watching my cpu temps climb out of control, a reboot into the BIOS quickly showed my pump rpm at zero.
A couple of reboots later and it kicked back in but after another reboot it stopped again and is now in a 1 in 10 chance of working properly.
I tried switching PWM headers on the board to no avail.
This morning I removed the pump and hey presto, when I boot the pc for a few seconds the pump works when not fitted to the the block. Pop it back in and it doesn't work.
I even have the front o11 distro plate spare so I swapped pumps.... Same damn thing! When fitted to the block it doesn't work but when out on the kitchen table no probs.
The loop is clean as a whistle with no signs of reside and there doesn't appear to be anything obstructing the pump when fitted to the block. I even carefully guided the pump into place whilst spinning to see if it was rubbing against anything... Nope! Kept on spinning fine. Power off and back on again and nothing!
This once had got me properly stumped.
Any ideas?
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1300359-ek-distro-block-pump-issues-help/
Well the pump does kinda levitate when powered. So it could move up and rub.
But if you leave the cable disconnected for control, does it still eventually stop?
I think I fixed it.
Strip and rebuild seems to have done the trick. Not sure why the other pump didn't want to work when fitted but when I placed the original back in place it spun up straight away and hasn't missed a beat since.
That particular system has spent the last 6 months powered down so maybe it just needed a bit of TLC. Its back in place and now being used every day so hopefully everything will be ok.
