so , randomly my sound quality drops , like really bad , and sometimes my mouse lags when that happens , ive been using LatencyMon from www.resplendence.com
the problem started after i got my rog strix oc 3090 , never had this problem with my 2070
i thought i fixed the problem , but then a month later it started happening agian 😞
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for  0:03:44  (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name:                                        DESKTOP-M2MNK6H
OS version:                                           Windows 10 , 10.0, build: 19041 (x64)
Hardware:                                             ASUS, ASUSTeK COMPUTER INC., ROG CROSSHAIR VIII HERO (WI-FI)
CPU:                                                  AuthenticAMD AMD Ryzen 9 3950X 16-Core Processor
Logical processors:                                   32
Processor groups:                                     1
RAM:                                                  32682 MB total
CPU SPEED
Reported CPU speed:                                   3493 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs):   3485.70
Average measured interrupt to process latency (µs):   3.955578
Highest measured interrupt to DPC latency (µs):       75.50
Average measured interrupt to DPC latency (µs):       1.183548
 REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs):              18.527054
Driver with highest ISR routine execution time:       HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%):          0.000281
Driver with highest ISR total time:                   Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%)                          0.000366
ISR count (execution time <250 µs):                   27244
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-999 µs):                0
ISR count (execution time 1000-1999 µs):              0
ISR count (execution time 2000-3999 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs):              3535.110220
Driver with highest DPC routine execution time:       ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Highest reported total DPC routine time (%):          0.014256
Driver with highest DPC total execution time:         nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 461.09 , NVIDIA Corporation
Total time spent in DPCs (%)                          0.039850
DPC count (execution time <250 µs):                   525525
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-999 µs):                7
DPC count (execution time 1000-1999 µs):              0
DPC count (execution time 2000-3999 µs):              2
DPC count (execution time >=4000 µs):                 0
 REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count:                 firefox.exe
Total number of hard pagefaults                       107
Hard pagefault count of hardest hit process:          60
Number of processes hit:                              6
 PER CPU DATA
CPU 0 Interrupt cycle time (s):                       3.741278
CPU 0 ISR highest execution time (µs):                6.943888
CPU 0 ISR total execution time (s):                   0.000507
CPU 0 ISR count:                                      599
CPU 0 DPC highest execution time (µs):                86.022044
CPU 0 DPC total execution time (s):                   0.242080
CPU 0 DPC count:                                      245022
CPU 1 Interrupt cycle time (s):                       1.894995
CPU 1 ISR highest execution time (µs):                1.583166
CPU 1 ISR total execution time (s):                   0.000038
CPU 1 ISR count:                                      50
CPU 1 DPC highest execution time (µs):                30.601202
CPU 1 DPC total execution time (s):                   0.000854
CPU 1 DPC count:                                      138
CPU 2 Interrupt cycle time (s):                       2.754467
CPU 2 ISR highest execution time (µs):                5.571142
CPU 2 ISR total execution time (s):                   0.000754
CPU 2 ISR count:                                      792
CPU 2 DPC highest execution time (µs):                3535.110220
CPU 2 DPC total execution time (s):                   0.045255
CPU 2 DPC count:                                      4962
CPU 3 Interrupt cycle time (s):                       2.693693
CPU 3 ISR highest execution time (µs):                9.689379
CPU 3 ISR total execution time (s):                   0.006070
CPU 3 ISR count:                                      6977
CPU 3 DPC highest execution time (µs):                101.022044
CPU 3 DPC total execution time (s):                   0.118998
CPU 3 DPC count:                                      9157
CPU 4 Interrupt cycle time (s):                       7.440474
CPU 4 ISR highest execution time (µs):                11.302605
CPU 4 ISR total execution time (s):                   0.002089
CPU 4 ISR count:                                      2261
CPU 4 DPC highest execution time (µs):                206.392786
CPU 4 DPC total execution time (s):                   0.347764
CPU 4 DPC count:                                      36197
CPU 5 Interrupt cycle time (s):                       3.081275
CPU 5 ISR highest execution time (µs):                9.118236
CPU 5 ISR total execution time (s):                   0.00040
CPU 5 ISR count:                                      328
CPU 5 DPC highest execution time (µs):                134.108216
CPU 5 DPC total execution time (s):                   0.043014
CPU 5 DPC count:                                      5181
CPU 6 Interrupt cycle time (s):                       5.145808
CPU 6 ISR highest execution time (µs):                18.527054
CPU 6 ISR total execution time (s):                   0.001805
CPU 6 ISR count:                                      1437
CPU 6 DPC highest execution time (µs):                3505.120240
CPU 6 DPC total execution time (s):                   0.273663
CPU 6 DPC count:                                      30772
CPU 7 Interrupt cycle time (s):                       12.404112
CPU 7 ISR highest execution time (µs):                14.118236
CPU 7 ISR total execution time (s):                   0.011946
CPU 7 ISR count:                                      10683
CPU 7 DPC highest execution time (µs):                332.274549
CPU 7 DPC total execution time (s):                   1.653174
CPU 7 DPC count:                                      169915
CPU 8 Interrupt cycle time (s):                       2.385083
CPU 8 ISR highest execution time (µs):                3.156313
CPU 8 ISR total execution time (s):                   0.000331
CPU 8 ISR count:                                      812
CPU 8 DPC highest execution time (µs):                64.869739
CPU 8 DPC total execution time (s):                   0.003628
CPU 8 DPC count:                                      1044
CPU 9 Interrupt cycle time (s):                       2.248313
CPU 9 ISR highest execution time (µs):                2.565130
CPU 9 ISR total execution time (s):                   0.000017
CPU 9 ISR count:                                      24
CPU 9 DPC highest execution time (µs):                23.466934
CPU 9 DPC total execution time (s):                   0.000748
CPU 9 DPC count:                                      176
CPU 10 Interrupt cycle time (s):                       2.645040
CPU 10 ISR highest execution time (µs):                2.464930
CPU 10 ISR total execution time (s):                   0.000042
CPU 10 ISR count:                                      47
CPU 10 DPC highest execution time (µs):                27.645291
CPU 10 DPC total execution time (s):                   0.001848
CPU 10 DPC count:                                      677
CPU 11 Interrupt cycle time (s):                       2.479949
CPU 11 ISR highest execution time (µs):                2.244489
CPU 11 ISR total execution time (s):                   0.000128
CPU 11 ISR count:                                      271
CPU 11 DPC highest execution time (µs):                75.581162
CPU 11 DPC total execution time (s):                   0.003622
CPU 11 DPC count:                                      663
CPU 12 Interrupt cycle time (s):                       2.500745
CPU 12 ISR highest execution time (µs):                5.280561
CPU 12 ISR total execution time (s):                   0.000534
CPU 12 ISR count:                                      792
CPU 12 DPC highest execution time (µs):                41.553106
CPU 12 DPC total execution time (s):                   0.010391
CPU 12 DPC count:                                      1955
CPU 13 Interrupt cycle time (s):                       2.303585
CPU 13 ISR highest execution time (µs):                1.863727
CPU 13 ISR total execution time (s):                   0.000020
CPU 13 ISR count:                                      26
CPU 13 DPC highest execution time (µs):                24.539078
CPU 13 DPC total execution time (s):                   0.000992
CPU 13 DPC count:                                      283
CPU 14 Interrupt cycle time (s):                       2.248683
CPU 14 ISR highest execution time (µs):                1.452906
CPU 14 ISR total execution time (s):                   0.000023
CPU 14 ISR count:                                      29
CPU 14 DPC highest execution time (µs):                35.250501
CPU 14 DPC total execution time (s):                   0.001232
CPU 14 DPC count:                                      427
CPU 15 Interrupt cycle time (s):                       2.120472
CPU 15 ISR highest execution time (µs):                3.036072
CPU 15 ISR total execution time (s):                   0.000044
CPU 15 ISR count:                                      46
CPU 15 DPC highest execution time (µs):                35.511022
CPU 15 DPC total execution time (s):                   0.000820
CPU 15 DPC count:                                      167
CPU 16 Interrupt cycle time (s):                       2.260475
CPU 16 ISR highest execution time (µs):                1.192385
CPU 16 ISR total execution time (s):                   0.000015
CPU 16 ISR count:                                      20
CPU 16 DPC highest execution time (µs):                31.873747
CPU 16 DPC total execution time (s):                   0.000389
CPU 16 DPC count:                                      104
CPU 17 Interrupt cycle time (s):                       2.238405
CPU 17 ISR highest execution time (µs):                1.743487
CPU 17 ISR total execution time (s):                   0.000009
CPU 17 ISR count:                                      8
CPU 17 DPC highest execution time (µs):                29.829659
CPU 17 DPC total execution time (s):                   0.000977
CPU 17 DPC count:                                      345
CPU 18 Interrupt cycle time (s):                       2.379869
CPU 18 ISR highest execution time (µs):                2.565130
CPU 18 ISR total execution time (s):                   0.000024
CPU 18 ISR count:                                      30
CPU 18 DPC highest execution time (µs):                65.971944
CPU 18 DPC total execution time (s):                   0.001274
CPU 18 DPC count:                                      316
CPU 19 Interrupt cycle time (s):                       2.414098
CPU 19 ISR highest execution time (µs):                2.304609
CPU 19 ISR total execution time (s):                   0.000140
CPU 19 ISR count:                                      369
CPU 19 DPC highest execution time (µs):                44.198397
CPU 19 DPC total execution time (s):                   0.004050
CPU 19 DPC count:                                      1330
CPU 20 Interrupt cycle time (s):                       2.466642
CPU 20 ISR highest execution time (µs):                6.252505
CPU 20 ISR total execution time (s):                   0.000194
CPU 20 ISR count:                                      364
CPU 20 DPC highest execution time (µs):                37.845691
CPU 20 DPC total execution time (s):                   0.003311
CPU 20 DPC count:                                      782
CPU 21 Interrupt cycle time (s):                       2.214107
CPU 21 ISR highest execution time (µs):                1.953908
CPU 21 ISR total execution time (s):                   0.000035
CPU 21 ISR count:                                      40
CPU 21 DPC highest execution time (µs):                43.747495
CPU 21 DPC total execution time (s):                   0.000670
CPU 21 DPC count:                                      114
CPU 22 Interrupt cycle time (s):                       2.266023
CPU 22 ISR highest execution time (µs):                2.304609
CPU 22 ISR total execution time (s):                   0.000026
CPU 22 ISR count:                                      30
CPU 22 DPC highest execution time (µs):                35.791583
CPU 22 DPC total execution time (s):                   0.000330
CPU 22 DPC count:                                      71
CPU 23 Interrupt cycle time (s):                       2.522635
CPU 23 ISR highest execution time (µs):                5.531062
CPU 23 ISR total execution time (s):                   0.000371
CPU 23 ISR count:                                      599
CPU 23 DPC highest execution time (µs):                34.929860
CPU 23 DPC total execution time (s):                   0.006791
CPU 23 DPC count:                                      1592
CPU 24 Interrupt cycle time (s):                       2.440908
CPU 24 ISR highest execution time (µs):                6.102204
CPU 24 ISR total execution time (s):                   0.000186
CPU 24 ISR count:                                      213
CPU 24 DPC highest execution time (µs):                35.290581
CPU 24 DPC total execution time (s):                   0.002557
CPU 24 DPC count:                                      335
CPU 25 Interrupt cycle time (s):                       2.198398
CPU 25 ISR highest execution time (µs):                1.252505
CPU 25 ISR total execution time (s):                   0.000011
CPU 25 ISR count:                                      11
CPU 25 DPC highest execution time (µs):                18.937876
CPU 25 DPC total execution time (s):                   0.000348
CPU 25 DPC count:                                      101
CPU 26 Interrupt cycle time (s):                       2.450350
CPU 26 ISR highest execution time (µs):                1.983968
CPU 26 ISR total execution time (s):                   0.000030
CPU 26 ISR count:                                      26
CPU 26 DPC highest execution time (µs):                34.659319
CPU 26 DPC total execution time (s):                   0.000950
CPU 26 DPC count:                                      246
CPU 27 Interrupt cycle time (s):                       2.384838
CPU 27 ISR highest execution time (µs):                8.667335
CPU 27 ISR total execution time (s):                   0.000110
CPU 27 ISR count:                                      88
CPU 27 DPC highest execution time (µs):                36.172345
CPU 27 DPC total execution time (s):                   0.004328
CPU 27 DPC count:                                      1551
CPU 28 Interrupt cycle time (s):                       2.260390
CPU 28 ISR highest execution time (µs):                2.234469
CPU 28 ISR total execution time (s):                   0.000043
CPU 28 ISR count:                                      42
CPU 28 DPC highest execution time (µs):                43.236473
CPU 28 DPC total execution time (s):                   0.001128
CPU 28 DPC count:                                      277
CPU 29 Interrupt cycle time (s):                       2.398168
CPU 29 ISR highest execution time (µs):                1.082164
CPU 29 ISR total execution time (s):                   0.000004
CPU 29 ISR count:                                      4
CPU 29 DPC highest execution time (µs):                31.743487
CPU 29 DPC total execution time (s):                   0.000321
CPU 29 DPC count:                                      68
CPU 30 Interrupt cycle time (s):                       2.996253
CPU 30 ISR highest execution time (µs):                5.370741
CPU 30 ISR total execution time (s):                   0.000122
CPU 30 ISR count:                                      105
CPU 30 DPC highest execution time (µs):                54.038076
CPU 30 DPC total execution time (s):                   0.035175
CPU 30 DPC count:                                      5399
CPU 31 Interrupt cycle time (s):                       2.862685
CPU 31 ISR highest execution time (µs):                4.168337
CPU 31 ISR total execution time (s):                   0.000139
CPU 31 ISR count:                                      121
CPU 31 DPC highest execution time (µs):                52.685371
CPU 31 DPC total execution time (s):                   0.045985
CPU 31 DPC count:                                      6167
https://linustechtips.com/topic/1300323-wireless-headsetmouse-issues/
