Sound Problems.
By
Sokol
in Troubleshooting
in Troubleshooting
Solved by AronMan13,
If you go onto sound settings on windows just type in sound settings then go to advanced settings from there you can set how loud the sound is in each headphone if you set them to the same then it should be the same that is how I fixed mine
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
3
6
Ishikudeska ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
