CPU Cooler Compatibility
Solved by mr cheese,
Just now, Sima01 said:I just wanted to have one, it looks much more nicer and I plan on upgrading a case later on so I could see all that through the panel.
If you really want an AIO, pretty much any of them should fit just fine. I have the EVGA CLC 280 and the pump is pretty large, but not any bigger than the Intel stock cooler. I will say, sure, it "looks cool", but you don't really need an AIO. Most air coolers like the NH-D15 do the work just as fine if not better, I only run an AIO because I paired it with noctua fans and ran it super quiet. Food for thought.
