GPU (?) running slow
Solved by Naijin,
16 hours ago, TheGoldenGamerr said:After I updated the drivers, the GPU does not reach 100% load anymore. I tested it with Heaven benchmark and it was running at 100% Im pretty dumb so i don't really know how to check the frequency, but this picture is what it says when running Heaven. The GPU doesnt reach 100% anymore in for example Overwatch, but it is still not the usual framerate that it should be. (Also im sorry that the picture is in Swedish, I hope you can understand it anyways)
You can check gpu frequency in for example MSI Afterburner (advanced) or GPU-Z, then compare that with cpu usage from task manager when playing a game.
.png.b694116b2e09ff900d87c2932d6ae0f1.png)
