so Ive tried installing kali linux multiple times in virtual box and even vmware without success , every time I try to install it there is a problem with installation
log file and screenshot : kali linux-2021-01-23-20-30-55.log
does anybody know how I can fix this ?
  • 4 weeks later...
Since it doesn't tell you exactly what has failed, you can just run the base install and then try to manually install files and figure out what's going wrong from there
