cpu fan header
Solved by 1982 Original,
17 hours ago, OwayBaway said:mine is an acer aspire gx 785 ur17, the bios has no fan control, its a very crap mobo
Buy a molex or Sata to 3 pin or 4 pin adapter. They are $5-$7 on Amazon. That will give you 12v full speed power for your pump.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
