Audio Buzzing
Go to solution Solved by AMICLG,
It's because of the USB the plugs, the audio cable inside not shielded and they probably share a common ground, it does this on almost every case which is why you always plug your headphones into the back plug on your motherboard.
I'm having problems with my front panel audio.  I get a high pitched buzzing when I plug any headphones or speakers in the front, but not the back.  I have a rosewill challenger-u3 case, an msi 970a-g43 am3+ mobo which I am using the onboard audio.  If someone could please help me with this, that would be much appreciated.
https://linustechtips.com/topic/129726-audio-buzzing/
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/129726-audio-buzzing/#findComment-1727066
Buy some extention cables...
i got a 3ft one for a few bucks :D
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/129726-audio-buzzing/#findComment-1727113
