cpu boosing issue
Go to solution Solved by BulletSponge,
my ryzen 5 3600 on idle tends to peg itself at 4 ghz for no reasean i even have the amd chipset driver with ryzen balanced mode plz help i have a aio and its idling a mid 40s
Main Pc: CPU: ryzen 5 5600x  Motherboard: Msi b450 gaming plus max  RAM: 32gb corsair vengeance ddr4 3200mhz ram  GPU: Nvidia rtx 2070 SUPER 8gb Case:  cooler master td500   PSU: corsair 750watt bronze80+  Cooling: Kraken x53 aio Storagewdblack snd750,3tb wd blue hdd
2nd Pc: CPU: ryzen 5 3600 Motherboard: Gigabyte AB350M-Gaming 3  RAM: 16gb 3000mhz gskill Aegis  GPU: Nvidia gtx 1650super 4gb  Case: Cooler Master MasterBox MB311L ARGB Airflow PSU: corsair cx 550watt 80+ bronze Cooling: Vetroo V5 CPU Air Cooler Storage: adata su635 240gb ssd, seagate 750gb 7200rpm hdd
3rd pc CPU: i7 2600 Motherboard: asus H61M-E  RAM: 16 gb ddr3 1333mhz GPU: nvidia gtx 1060 3gb Case: thermaltake versa h18 PSU: evga 450watt 80+ bronze Cooling: Cooler Master I70C (Copper Core) Mini CPU Cooler Storage: crucial mx 500 500gb ssd, wd blue 1tb 7200rpm hdd
https://linustechtips.com/topic/1297165-cpu-boosing-issue/
my cpu ryzen 5 3600 with no stress on it running at 6 percent usage boosts to 4ghz on idle and idles with my aio at the mid 40s plaz help i only want it to boost when stressed
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416164
Hey there!
Please create only one thread for each issue that you have. This will help everyone communicate with you better.
I have merged both threads. Cheers!
~Energycore
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416177
1 minute ago, abalone said:
ASUS Motherboard?
no msi board
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416185
What processes are using the processor when you say "no stress on"?
a few game l;aunchers wallpaper engine and discord
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416198
I'm not familiar with MSI boards, but try to look for anything surrounding terms like "Turbo", "Boost", "Performance", "Enhancement", "Multicore..." in the BIOS. I know some ASUS boards have Turbo Mode enabled by default, which is located in the Advanced settings, and which keeps the clock at high speeds at all times.
Also, check Windows power management (Win + R -> powercfg.cpl) and tell me what power mode you're on.
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416215
im on ryzen balanced mode and in bios i have core performince boost on and it should just boost when under heavy stress
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416222
Does changing the power mode in windows to Energy Saving or Balanced mode help?
Also, what software do you use to monitor your CPU?
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416236
energy saving does help but woundent that keep my performince low even during stress it goes down to 2ghz which is to low  and i use hwinfo
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416239
windows balenced makes it stuck at 4ghz to
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416241
Go into the advanced options of the Ryzen power mode and check this number.
If you lower this and the clock doesn't go down, that could either mean that the boosting is set in BIOS, or that you have faulty drivers/high CPU background usage
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416249
it went down a little should i lower it more
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416256
That's up to you. My clocks are running at 80-100% all the time.
If temperatures are fine and you're not trying to save a minimal amount of energy, I see no reason trying to lower the clocks.
I'm no professional, someone else would have to confirm this.
Also, your CPU will always be a little "stressed" whilst surfing or running ANY background apps.
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416266
Is it normal that that made barely a difference tho
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416274
When I turned it down
https://linustechtips.com/topic/1297165-cpu-boosing-issue/#findComment-14416275
