I got a Msi 3080 gaming x trio. And when I got it I tried running a triple a game. When I start one my cpu speed goes down base speed then after a few mins it goes down to 0.7 ghz. I have had the cpu for five months and before my 3080 I used a EVGA 1050ti. This issue occurred right as I got my GPU. After some trial and error i found out that when i uninstall my gpu driver the issue is fixed. but as soon as i re-install it the issue comes back. And help would be greatly appreciated
Specs
Case spec-omega black
Intel i9 10900kf
Asus z490 e gaming
Corsair RM 850x
XPG GAMMIX 2TB S11 NVMe
Trident z 2x8Gb 3200mhz
corsair h100i duel radiator
Hopefully people will see this
https://linustechtips.com/topic/1295531-i-need-help/
  • have you tried resetting your bios? clear the CMOS for this
  • try uninstalling and reinstalling your GPU drivers using DDU. this
  • check if your PSU is working properly. the 1050ti was a relatively low powered card and when you changed to a 3080, your cpu may be not getting enought power? though this is very unlikely because i would assume the system would just crash when you start a game.
https://linustechtips.com/topic/1295531-i-need-help/#findComment-14404223
