Will urdimm be Compatible
Go to solution Solved by loganrulz2833,
it seems it really only supports up to about 12 ram modules of DDR4 2933mhz of registered dimm (6-channel). So it really wouldn't and as far as i am aware server workstations don't support unregistered dimms.
So Iam considering buying the asus pro ws c621 for my next build it's gonna be a workstation btw but Iam not sure if the board itself is compatible with urdimm (with no ecc) its not mentioned on the website if it's supported or not
The only thing mentioned about ram that it does support Rdimm (with ecc) but to be honest the rdimm look bad and Iam planning on using corsair dominator platinum rgb with a xeon platnium not sure which one yet help would be appreciated
https://linustechtips.com/topic/1294928-will-urdimm-be-compatible/
