I have an old nvidia geforce 9800 gtx+ and I bought a new psu its a bequiet 80 plus bronze psu. When I changed it and started the pc the gpu fan started making a loud sound and the pc wont boot. There is a green light on the gpu which shows thwt the gpu is connected properly because if I disconnect one of its cables its red, so Im guessing thats what its for. pls help
https://linustechtips.com/topic/1294923-gpu-problem/
3 minutes ago, yaboistar said:
again, you're making another post about the same issue just under a different title and subforum. you were already given answers in previous threads that you appear not to have taken on-board. reposting it so that "dud i want people to see it" won't change the advice you've been given to advice you want to hear
ok thanks for the help
https://linustechtips.com/topic/1294923-gpu-problem/#findComment-14399462
Guest
