Odd instability issues on new Ryzen machine
Solved by Master Disaster,
Check what voltage the SoC is getting, its generally in the same area of the UEFI as CPU Vcore. It will probably be at 0.9v to 1.0v on Auto, try bumping it up to 1.1v (you can go up to 1.2v safely).
Also standard Ryzen new owner PSA, don't bother trying to OC your Zen 2. You won't be able to go any further with a manual OC than Boost can already achieve automatically, all you are doing by setting an all core OC is removing the CPUs ability to do single core boosting. (You can watch LTTs "Don't build a Hackintosh" video to see this in action). The only thing you should be enabling is D.O.C.P, leave everything else on Auto.
