I currently am building my third or fourth PC , this time being for my wife who occasionally games.
Long story short, I bought a pretty generic corsair case and a ASRock AMD mobo (AM4 Socket) B550. The problem I have and not even sure if it's an issue is that there are extra mounts for what seems like a bigger mobo type. Do I need a different case or is this even an issue at all?
Hopefully the picture adds some clarity for my poor explanation. Any help appreciated, thanks!
https://linustechtips.com/topic/1291930-mobo-small-for-case/
Larger chassis types typically support various motherboard sizes. While I wouldn't necessarily consider it an issue, if you get a chassis that's way oversized for a motherboard, then it's probably a waste of money. Depends though.
In this case, I would say it's fine. But you do have a bit of room for expansion in the future.
https://linustechtips.com/topic/1291930-mobo-small-for-case/#findComment-14377711
Thanks 😊
https://linustechtips.com/topic/1291930-mobo-small-for-case/#findComment-14377716
Meh :P
F@H
GPD Win 2
https://linustechtips.com/topic/1291930-mobo-small-for-case/#findComment-14377718
Just now, Kilrah said:
Meh :P
Looks like you could use some motherboard for your chassis.
https://linustechtips.com/topic/1291930-mobo-small-for-case/#findComment-14377723
12 hours ago, AdkatkaShow said:
Why is that? And please, no "because manual says so" answers.
Well, "becasue the manual says so", and it does :)
Your CPU has 2 memory channels. If you populate both you get twice the memory bandwidth.
F@H
GPD Win 2
https://linustechtips.com/topic/1291930-mobo-small-for-case/#findComment-14379024
