Finished my 2TB drive (named "BULK") and discovered that there's a folder with 545 GB of data on it.
I don't know what it is, but I'm going to ask my dad - I've put maybe 100GB of data on here total.
Anyway.
I started copying my 250GB drive (which interestingly is the only SATA II drive in there, and also 7200RPM, named "Storage") and it kept telling me that it couldn't copy the folder "Low".
It's happened twice now, and I'm halfway through the data.
Does anyone know what this folder is and why it's noncopyable?
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1291308-low-folder-not-copying/
That's a whole lot of porn. 🤣
24 minutes ago, ragnarok0273 said:
the folder "Low".
It isn't "LocalLow"? That would be one of the AppData folders.
This drive had Windows on it?
If you don't know what the folder is, why do you need to copy it?
What is the location of the folder? Like "C:\Users\Butts\...etc..."
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1291308-low-folder-not-copying/#findComment-14373572
Folder's called "WindowsImageBackup"
Nope. Just "Low".
Nope - it's a 250GB HDD used as a secondary storage drive. Although - my dad used this, plus the 2TB one, as storage for almost everything non-Windows essential.
I'm backing up the drive.
It has many, and not all have files in them:
F:\Temp\Users\Bob\AppData\Local\Microsoft\Windows\PrivacIE\Low (no files)
F:\Temp\Users\Bob\AppData\Local\Microsoft\Windows\IETIdCache\Low (no files)
F:\Temp\Users\Bob\AppData\Local\Microsoft\Internet Explorer\UserData\Low (files)
F:\Temp\Users\Bob\AppData\Local\Microsoft\Windows\INetCookies\Low (files)
F:\Temp\Users\Bob\AppData\Local\Microsoft\Windows\INetCookies\DNTException\Low (no files)
F:\Temp\Users\Bob\AppData\Local\Microsoft\Windows\INetCache\Low (files)
F:\Temp\Users\Bob\AppData\Local\Microsoft\Windows\IECompatUaCache\Low (no files)
F:\Temp\Users\Bob\AppData\Local\Microsoft\Windows\IECompatCache\Low (no files)
F:\Temp\Users\Bob\AppData\Local\Microsoft\Windows\History\Low (files)
This same sequence of filepaths repeats for every user there ever was and is on this computer.
Looks kinda like Internet Explorer stuff to me, and if it is, I don't care anymore.
https://linustechtips.com/topic/1291308-low-folder-not-copying/#findComment-14373590
It seems like those are mostly hidden folders for temp files. I wouldn't worry about trying to back those up.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1291308-low-folder-not-copying/#findComment-14373624
Well, they're going to be gone forever now!
Two reasons for backing up:
1. To back up
2. To recreate my NTFS partition because Linux said "NTFS partition is unstable, unmounting..." while booting my installer.
https://linustechtips.com/topic/1291308-low-folder-not-copying/#findComment-14373625
  • 2 years later...
It used to be named "Low" in older versions of Windows (maybe XP).
When Microsoft changed the folder layout and nomenclature (possibly from Vista) to have a "Users" directory instead of "Documents and Settings" they also introduced some kind of weird symlimking so that 'legacy' apps could still find the files.  Unfortunately, they made a botched job of it, and have still not fixed the issues introduced even to this day AFAIAA.  If you try to access these links using File Explorer, DOS, another OS, or probably anything not running in "compatibility mode" within Windows, you'll get an access denied or unspecified error.  But there's nothing in there, they are just symlinks.
https://linustechtips.com/topic/1291308-low-folder-not-copying/#findComment-15831688
