installed my asus hyper m.2 x16 gen. 4 with 4x samsung 970 evo plus 500gb and i seem to experience a problem that it only shows one of the ssd installed not the other 3 also.
Im planning to a fresh install of windows on it.
mobo: rog strix z390 E-gaming
CPU: i9 9900k
https://linustechtips.com/topic/1290855-using-asus-hyper-m2-x16-gen4-problems/
CPU: i9 9900k
can you check your raid configuration?
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
gonna need a guide for that. im not very good at finding the newest stuff in bios.
Update: ive been into the bios only option is to enable the hyper pci-e expansion unit. couldnt find any settings for raid configuration. and after enabling still only one NVMe ssd detected
