Coil whine help!
Coil whine is a natural phenomenon where inductors or transformers vibrate in a frequency that falls in the human range of hearing (20-20000 Hz). You just have to live with coil whine. Coil whine may not happen on lower end cards due to graphical settings being lower than their higher end counterparts. Also keep in mind, the higher the FPS, the more prominent coil whine may appear as the card is processing more frames per second.
If your new GPU makes coil whine, you can either live with it or send it back and get a replacement. You can turn up the case fans so the noise they generate overcomes the coil whine from the graphics card. Also, if it happens during a warranty period, some manufacturer's will not accept coil whine for an RMA while some others do so do research in the warranty on the manufacturer's website.
