Help on aesthetics
Solved by bellabichon,
That watermark is there because you're using an Insider Build of Windows. The only way to remove it is to go back to a main release, not a beta version.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
