Problems with 2 different GPUs in one PC
Solved by jaslion,
17 minutes ago, Amigo4321 said:
Discord is one of those apps that will refuse to swap over and use the card it launched on thus only creating more work for the 2070. Just take the 710 out of the system and lower the settings a bit or close the programs causing the problems.
