Budget (including currency): ~2000 USD
Country: US
Games, programs or workloads that it will be used for: Cyberpunk, COD, MC, Gaming and Productivity
- Using 144Hz monitor
So I am looking into building my first PC and am wondering a few things. First (And most importantly) Intel or AMD. From what I know a CPU for this kind of build would be around $350 so I was wondering what kind of CPU I should choose.
If intel I for sure am going for a 3080 but once again if AMD I don't know whether to go Nvidia or AMD.
If anyone has tips or build please leave them below.
https://linustechtips.com/topic/1289774-first-pc-build/
Country: US
geometry is hard
b550 > x570
https://linustechtips.com/topic/1289774-first-pc-build/#findComment-14361952
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1289774-first-pc-build/#findComment-14361959
Just now, MarvintheParrot said:
Great build! But I would recommend a higher wattage PSU. I would also recommend a 5800x. Its a great CPU and a few $$$ less.
I mean he said that he is doing productivity workloads, and he has the budget for a 5900x, so why not?
Also 750W should be okay with the RM. if op wants to do 850 he can always change that.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1289774-first-pc-build/#findComment-14361967
Sure, but I always think that if there is a place to save some money, then make it happen. I would go with the 5800x, but your right. If OP wants to go with a 5900x, then they should. But I really would go with a higher wattage PSU if OP is gonna get a 5900x.
https://linustechtips.com/topic/1289774-first-pc-build/#findComment-14361991
I also want it to last for quite a while. I have a question too. NVME or M.2 drives are used primarily over SSD's for what purpose.
https://linustechtips.com/topic/1289774-first-pc-build/#findComment-14362095
geometry is hard
b550 > x570
https://linustechtips.com/topic/1289774-first-pc-build/#findComment-14362112
