Low gpu usage!
Solved by Subduck,
From the information i'm seeing after having a quick search on the internet about the problem, your best bet would be to try an older Radeon GPU driver.
You can choose from all the past drivers at this link once you select your OS: https://www.amd.com/en/support/previous-drivers/graphics/amd-radeon-5600-series/amd-radeon-rx-5600-series/amd-radeon-rx-5600-xt
Uninstall your old driver using DisplayDriverUninstaller(DDU), walkthrough here:
