Can you post pictures of where you have it plugged in at?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1288673-someone-help/#findComment-14353426
so what you have there, is your 4pin EPS plug.. thats not where that belongs.. there are little cables from the front panel that goes there. It will have the words Power SW on it and they go there.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1288673-someone-help/#findComment-14353435
I did these are the plugs I had in (sorry for the bad quality)
https://linustechtips.com/topic/1288673-someone-help/#findComment-14353452
ok, so the PowerSW belongs on the top 2 to the right. If that doesnt work, then your case may be defective. You can try and short the jumper by using a screw driver and touching the 2 pins. (This is 100% safe to do)
EDIT: Relooking at them, the orientation should be Horizontal, looks like you have them vertical. They should be like this - not |
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1288673-someone-help/#findComment-14353453
Mk the case might be defective because I just took everything out checked the cpu no missing pins did it the way you told me from the message and the edit preciate the help I’m just going to order a new one
https://linustechtips.com/topic/1288673-someone-help/#findComment-14353457
You just have the jumpers oriented incorrectly on the pins when I took a closer look at the picture. You should have them Horizontal on the pins, going left and right, not up and down.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1288673-someone-help/#findComment-14353460
