Low GPU and CPU usage after upgrade
Solved by Moonzy,
2 minutes ago, kopper said:Dang.. I used DDU but reinstalled geforce experience and the drivers from there. Is there any difference between direct driver downloads from there website and geforce experience?
No it should be okay
You could check graphical settings, some of them are heavier on CPU than GPU perhaps, lowering them might yield better results
You can crank anything that doesn't affect CPU usage up since you have so much GPU headroom
But do consider upgrading you CPU when you next upgrade your PC, it's quite an unbalanced pairing for AAA games lol
