Kernel Power. I've tried everything.
I've build my first pc a month ago. It posted, it's working, the temps are not bad. I've been using almost arounnd the clock for the past weeks.
However, I keep getting the same Kernel Power 41 (63). It is not a blue screen, the computer just shuts down. It sometimes happens when opening or closing a game. Weirdly, never while playing games, I've spent hours playing and it went fine.
It also happened a couple of times while using adobe software.
Now, I've done my research and tried a bunch of stuff, and while the frequency of the error diminished, it is still happening.
Things I've tried:
- Resetting the Ram
- Updating the BIOS and drivers
- Formatting the PC
- Disabling XMP
- Disabling Fast Startup
- Power settings set to high performance (Hard Drive Shut down never)
- Disabling duplicate audio drivers
- Aida 64 Stress Test (It all went fine, temps were good and the PC did not shut down)
- Change one BIOS setting to typical current idle
- Tested the system ssd with samsung's own software and it was ok
- Resetting all the power supply cables
I know that it might be the power supply being insufficient, but I do not think that's the case. My specs:
Ryzen 5600x
Cooler Master Hyper 212 Black Edition
B550m AORUS PRO
DDR4 32GB 3200mhz (2x16) T Force Dark Z
Samsung 860 EVO 500GB
Seagate Barracuda 1tb 7200rpm
RTX 2060 ASUS TUF OC 6GB
650 WATT PSU from Corsair (VS 650 80 PLUS WHITE)
6 fans and the case are from a brazilian brand (Pichau)
Any help is welcome. Thanks.
Examples of the error:
The error has happened when:
Opening Cyberpunk 2077 (Either when pressing play or during the load screen)
Opening Minecraft (As soon as the play button is pressed)
Closing Star Wars Battlefront
While using photoshop
The full error:
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 12/26/2020 3:33:33 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-4O1E4D2
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2020-12-26T18:33:33.7534281Z" />
<EventRecordID>1931</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-4O1E4D2</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
