Is this psu good
4 members have voted
  1. 1. Is this psu good
    • Yes
      1
    • no
      3
So i have a gtx 980 ryzen 2600 16 gbs of ram and a b450 mobo. I saw this was in the B tier on the psu list so i was wondering if i should get it. If not what are some other psus for the same price?
There is also another psu by Silverstone i was wondering about getting. Its also cheaper!
https://linustechtips.com/topic/1285903-good-power-supply/
You don't have anything too power hungry, so a B-tier unit should be fine. I'd probably go with the Be Quiet unit if it were me, but that Silverstone unit is probably just a rebranded Seasonic, so it would be fine as well (don't quote me on that, check for yourself before buying)
https://linustechtips.com/topic/1285903-good-power-supply/#findComment-14334103
For future reference, the Silverstone is actually a CWT PSU, specifically using the GPS platform, and not a Seasonic. Also only 3 year warranty...oof. I'd personally take the be quiet! over Silverstone.
There's also the Antec Earthwatts Gold Pro 550w for $80 on Amazon. It's a tier A PSU that is a rebranded Seasonic Focus GM, with a 7 year warranty.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1285903-good-power-supply/#findComment-14334163
Thanks, figured it was rebranded, just didn't know who was the OEM, and figured most are Seasonic
https://linustechtips.com/topic/1285903-good-power-supply/#findComment-14334171
How in the world did you arrive at that conclusion, and why would that make the PSU fine? Seasonic is perfectly capable of selling garbage, just like any other brand
https://linustechtips.com/topic/1285903-good-power-supply/#findComment-14334563
It would be easier if you actually wrote which models you're looking at, and linked where you're buying from
https://linustechtips.com/topic/1285903-good-power-supply/#findComment-14334567
