So I got the cooler master mb511 case, it has 3 front facing fans which were surprisingly fixed as exhaust fans. However I took out the top two and changed the orientation, sadly the bottom most fan does not come off i.e. it does not have screws. It seems to be fixed, any way of removing and changing the orientation?
https://linustechtips.com/topic/1285713-case-fans/
Are you sure? Those just look like pins.
Have you tried using a needle nose plyers to remove them?
Can you see the backside of them from in the case? Or would you have to remove the radiator to do that?
And are you sure this is backwards?
Typically the exhaust side has the manufactures' information on the exhaust side along with the wire connected to the motor.
I don't see that here.
An easy way to dummy check, take a piece of paper and hold it close to the fan and see if it gets sucked towards it or gets pushed away.
My 2020 Upgrade: CPU: Ryzen 5 3600; MB: MSI X570 Tomohawk WiFi; Memory: G.Skill Ripjaws V 32GB 3600 MHz; Case: Lian Li Lancool II Mesh Performance; PSU: Corsair RM550X 80+ Gold; Storage: WD Blue 500GB SSD; Seagate 4TB Compute HDD; Monitor: GIGABYTE G34WQC 34" 144Hz Curved Gaming Monitor, 3440 x 1440 VA 1500R Display
Previous Components Still Using: GPU: MSI GTX 1070 (bought Used); Storage: WD 3TB Green HDD,WD 1TB Black HDD, SanDisk SSD PLUS 240GB
Previous Monitor I want to VESA mount: LG 29UB55-B 29" Ultrawide 1080p 60Hz IPS
https://linustechtips.com/topic/1285713-case-fans/#findComment-14333674
The fan that is fixed in with pins is in an intake position.  Most fans the side with the supports for the motor is the side the air comes out.
You have turned the upper fans above it into exhaust fans.  If you want them as intakes you need to turn them back around.
AMD R7 3700X
32GB Mushkin Redline 3200MHz DDR4
Aorus A530 Elite WIFI
Bequiet Shadow Rock 3
EVGA RTX 2060 Super
Phanteks AMP 650W
Fractal Pop Air
Windows 11 / Arch Linux
https://linustechtips.com/topic/1285713-case-fans/#findComment-14333716
