Hi All,
I have a Ryzen 3950X and I have been using my memory I carried over from my i7 6700K Build.
My Current is 2666MHz C16 Vengeance LPX 4x8GB
I was looking to upgrade memory but feel like its more of a mine field than I thought.
I will be looking for 4x16GB but likely just buy 2x16GB to start with.
I understand how to work out latency etc but I cant decide what will be better for me..
I am Looking Corsair Vengeance RGB PRO 32GB 3600MHz C18
But I see they do 3200Mhz C16 and 3000MHz C15 these all work out to have the same real latency so what one would you pick?
Open to any other suggestions too.
I used my computer for  Gaming, Video Production & 3D Work
Any Help Much appreciated
https://linustechtips.com/topic/1284217-memory-upgrade-help/
Get the 3600mhz kit. This will allow you to run your Fclock at 1800mhz as well, the sweet spot for Zen 2 CPUs.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1284217-memory-upgrade-help/#findComment-14323336
Thanks for that. Are you able to elaborate a little what that means. I have a heard about the Fclock and stuff but not read much on it.
Thanks
https://linustechtips.com/topic/1284217-memory-upgrade-help/#findComment-14323341
F Clock is the infinity fabric clock. This is the link between the CCX's, or the core chiplets.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1284217-memory-upgrade-help/#findComment-14323345
Thanks,
I found this G.Skill Trident Z RGB 32GB Kit DDR4 3600MHz RAM C17 would that be a better option its £55 more expensive
https://linustechtips.com/topic/1284217-memory-upgrade-help/#findComment-14323361
This is the kit I personally use with my 3700x and was able to tighten the timings up using the Ryzen DRAM calculator.
https://www.newegg.com/ballistix-32gb-288-pin-ddr4-sdram/p/N82E16820164174?Item=N82E16820164174
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1284217-memory-upgrade-help/#findComment-14323364
