I hope this is the right place to post this please let me know and i'll post elsewhere.
So i am upgrading to an Asus Prime x570 pro which has 1 a-rgb header (gen 2) and 2 regular rgb headers. I want to install 6 argb fans (lian li bora digital http://www.lian-li.com/bora-digital/) . Now the fans come with a pwm splitter for 6 fans but an argb splitter for 3 and i came to the conclusion reading some other posts that running so many from one header isnt possible due to power limitations. So i ended up finding a cooler master powered splitter (https://www.coolermaster.com/catalog/coolers/rgb-accessories/masterfan-argb-and-pwm-hub/) that also does pwm and has extra sata power.
If i go with argb and pwm from motherboard to the splitter that has sata power should i be able to run the 6 fans from it?
https://linustechtips.com/topic/1283505-rgb-help/
