PS5 controller with Bluetooth
Solved by FrowningHippo,
Hello!
A Bluetooth 5.0 dongle should perfectly fine. It's not exactly the same thing. (They are different versions after all for more detail take a look here: Link).
The difference between the two versions seems to mostly come down to improvements in location tracking of the bluetooth signal. Making it easier for connected devices to pinpoint the location of eachother. In general you won't need this for PC games that support controllers as far as I am aware. And if it becomes a thing in the future I suspect it to be fairly niche untill the tech hits the mainstream market. (By that I mean companies incorporating it over time which will probably happen in the upcoming year(s).)
