Hi, I recently purchased a RTX 3080
and was disappointed by the average
FPS I was getting in game. (Overwatch)
The reason for the purchase was to get constant 400fps in game or at least constant 300+ for my high refresh rate monitor.
I anticipated that it would be super easy to get these numbers with my system but was not able to achieve those numbers.
System info:
X570 ASUS TUF Gaming Motherboard
Ryzen 3800x Overclocked to 4.45Ghz (stable)
MSI VENTUS 3X GeForce RTX 3080
16GB of Samsung B die ram 3800Mhz
Corsair CX750M Power supply
ASUS TUF 1080p 280hz monitor
I get a constant 400 max fps in the training room but in an actual game I get around 200-300 on average even with low settings.
It sometimes dip down to 140-180 fps.
And the gpu usage sits around only 30-35%.
The average fps count is very similar even in Ultra settings as well but the gpu usage jumps to about 55-60% range.
When doing a synthetic gpu benchmark I reach 100% GPU load easily.
Is this just the game lacking optimization for the new RTX 3000 series? or the nvidia driver not optimized for overwatch well enough?
I’m pretty sure nvidia will newly optimize overwatch again when overwatch 2 hits the market but I am looking for a fix before that.
Things I have tried that did not work:
Optimizing 3d settings in Nvidia control panel to Maximum performance.
Setting Windows power management to Maximum performance.
Disabling / Enabling G sync
Nvidia reflex on / off
Nvidia V sync off / fast
Fresh installing Windows 10
DDU nvidia driver and reinstalling it in safe mode.
Overclocking gpu / stock
On a side note,
During full load, stressing both cpu and gpu at the same time, the max power draw is about 500-550w range. So it is not a insufficient power issue.
Is this truly a CPU bottleneck at 1080p?
It is a Ryzen 3800x all core overclocked to 4.45Ghz stable.
Cinebench R20 score reaching 5300.
Any thoughts or input would be helpful thank you.
https://linustechtips.com/topic/1282964-rtx-3080-low-gpu-usage-and-fps/
  • 1 month later...
in order
COMPLETE A CLEAN INSTALLATION (look for overwatch but it is the same idea)
Sometimes issues occur where files are corrupted, permissions aren’t set correctly, or certain aspects of the game aren’t installed correctly. To fix this we need to completely uninstall PUBG and associated files.
1. Uninstall PUBG
2. Go to your Steam library
3. Right Click on PLAYERUNKNOWN'S BATTLEGROUNDS and select Uninstall
4. A windows will pop up asking for confirmation, click on Delete
5. Remove associated files
6. Press Windows Key+R
7. Type in %localappdata% and then press Enter or OK
8. Delete the folder TslGame
9. Navigate to Program Files (x86)\Common Files\BattlEye and delete the file BEService_pubg.exe
10. then erased  download cache
FLUSH DNS
1. Press the Windows key and in the search bar type “CMD”
2. Right Click the Command prompt shortcut and select “Run As Administrator”
3. In Command Prompt, Type ipconfig /release
4. Press [Enter]
5. Type ipconfig /renew
6. Press [Enter]
7. Type ipconfig /flushdns
8. Press Enter
9. Relaunch the game and test your connection
Run DDU IN windows safety mode
Install last driver nvidia without geforce experience
Download PUBG and play
(i desactivate xbox game bar too, capture, but idont think it is the problem)
I know you make that but try that in this order. itry to remember if i do other think
