Hello
I was transferring my pc from an old case to a new case. After I hooked everything up and I turned it on the ez debug light for the cpu lit up. I tried a few things. I unplugged and replugged the cpu cables and nothing changed. I unplugged the cpu power cable and started it up and the light next to the CPU socket on the mother board lit up along with the debug light. I then plugged everything back in and took off the cooler and took out the cpu to check for bent pins which I didn’t see any, I then reset the cpu and turned it on without the cooler for a few seconds and the debug light stayed on. Idk what happened and what’s broken. Please help
https://linustechtips.com/topic/1282536-cpu-ez-debug-light/
