Threadripper won't post
Go to solution Solved by B.Rms,
Just updating for future reference in case it can help anybody:
Mobo was definitely dead. I sent it back to the shop (it was only 2 months old). All other parts are alive and happy working on the new board: Asus Strix E Gaming.
I really feel a quality difference now between Asus and Gigabyte both in hardware and software. Even though the GB board is a bit cheaper, I think the price difference doesn't justify some of its drawbacks when I compare them both.
To be fair to the GB board, it did run cooler. The new Asus forced me to improvise an extra fan just next to the GPU because the chipset was hot as hell (around 80 C on idle) and its whinny fan was full speed driving me crazy. The heat from the GPU was killing it and I have a case with good airflow. With a 140mm fan blowing directly on that region now, the chipset stays at around 65 C and its fan noise is gone.
Case closed :)
Hey everyone. First of all, I did my share of Google on this and I found out everything I needed to know about it. But I have something more...
My TR build stopped posting for no good reason (MB: Aorus Pro WIFI, no OC). The little red leds jump from CPU to DRAM and stay on DRAM. Every 20sec or so, it goes to CPU for a short moment and back to DRAM.
I did all the troubleshooting Google found for me, tested every single piece of hardware in it, everything works fine with another MB+CPU, including the RAM. Most people diagnose it as a short somewhere on the board, so I've also taken the MB out of the case and ran it like that, same results. So I'm down to CPU or MB failure (or both).
But I was taking a closer look at the RAM sockets and I noticed 2 of them have some lighter spots (check the photo, socket on the left) and I'm pretty sure the plastic around those spots isn't very straight anymore. So my question is: has anyone seen this before and is this probably what's causing it? Could the RAM sockets short out and distort like that? Both sockets with those lighter spots weren't being used. Also every RAM socket has "1.2V" written on it, while the XMP of the RAM will kick it up to 1.35V. But I would think it can take that?
Also any chance a short in the RAM sockets can kill the CPU? I'll be getting a new mobo tomorrow (can't wait till they fix this one) and I'll test the CPU then, hoping it's just a dead mobo...
Threadripper 3970x | ASUS ROG Strix TRX40-E Gaming | Corsair HX1200i | 64 GB DDR4 Ripjaws-V 3600Mhz CL18-22-22-42 | Gigabyte RTX 3090 Xtreme Waterforce | Obsidian Series 750D Airflow | 250GB WD Blue SSD SN500 NVMe M.2 | 2x Samsung 860 Evo 1 TB Aorus 8 TB NVMe PCIe SSD | Nocuta NH-U14S TR4-SP3 | 3x Corsair ML120 Pro RGB | 1x Corsair ML140 Pro RGB | 1x Noctua NF-A14 | 1x Corsair AF140L |
https://linustechtips.com/topic/1281627-threadripper-wont-post/
try that then also try new ram if it still. don't work
https://linustechtips.com/topic/1281627-threadripper-wont-post/#findComment-14305611
I did try different RAM which had worked with this MB in the past and is being used on another build now. No joy.
https://linustechtips.com/topic/1281627-threadripper-wont-post/#findComment-14305623
Have you tried checking the torque of the screws that hold the processor in? Use that tool they provide with the processor.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1281627-threadripper-wont-post/#findComment-14305629
prob mobo then if not I don't want to say it  because that cpu expensive as f but the cpu may be dead or one of the pins may be bent
https://linustechtips.com/topic/1281627-threadripper-wont-post/#findComment-14305631
why does it say u posted the same thing 2wice
That's strange...it only shows I posted once...I know I get notifications from peoples reactions or quoted me twice sometimes for some reason.
https://linustechtips.com/topic/1281627-threadripper-wont-post/#findComment-14305639
I reseated the CPU 3 times by now and I always did it very carefully using the Ryzen tool. Also checked the pins with a magnifying glass, they all seem to be just fine.
That's my fear too. But it's still in the warranty and since I haven't OC'ed, I'm trying to figure out if those marks on the RAM sockets are normal because I can show the shop then that something went wrong with the mobo itself.
https://linustechtips.com/topic/1281627-threadripper-wont-post/#findComment-14305648
Ok, then its a probably cause the motherboard is defective. For those RAM slot discolorations...can you rub it off? Kinda looks like thermal pads that oozed a little bit.
https://linustechtips.com/topic/1281627-threadripper-wont-post/#findComment-14305655
Case closed :)
https://linustechtips.com/topic/1281627-threadripper-wont-post/#findComment-14315136
