Budget (including currency): 1500$ USA
Country: USA
Games, programs or workloads that it will be used for: I dont really have a genera of games i play lots of them and they mostly the hard ones to run plus i also wanna run more mods on minecraft without lagging all over please and thank you!
https://linustechtips.com/topic/1280509-i-need-a-build-please/
I give you build. Bit over budget but that is because i could not find a reasonably priced CPU. You could probably find the CPU for cheaper and buy that instead. :)
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1280509-i-need-a-build-please/#findComment-14297438
use this, i was going with a all msi build, but nah use this but it lacks rgb do you want rgb?
https://linustechtips.com/topic/1280509-i-need-a-build-please/#findComment-14297444
No offense but as much as i would want a 3080 its mostly always out of stock and hard to get. Unless they are doing a restock soon? but amd i able to configure this and make it into a 2080 or 2070 or something or even a 5700xt?
https://linustechtips.com/topic/1280509-i-need-a-build-please/#findComment-14297475
get a 5700xt or a 2070 super
https://linustechtips.com/topic/1280509-i-need-a-build-please/#findComment-14297479
