Raspberry Pi 4 Wifi not working
Hey, my raspberry pi 4 just wont connectto wifi whan i plug in a cable it works whan i try to conect to wifi conection, it fails and than deosnt show any wifi conections availible anymore.
if there is any networking in the console that i need to know please let me know,
if not than can you please help me with reclaming the thing?
https://linustechtips.com/topic/1280433-raspberry-pi-4-wifi-not-working/
When I've run into this it's usually because wifi is being blocked by rfkill. I think this is done by default until you choose a country/locale using raspi-config. If you don't want to try that or it doesn't help, you can try unblocking it using the following command and then trying to start the wifi:
sudo rfkill unblock wifi
If that doesn't help, you can try some more things on webpage: https://raspberrytips.com/disable-wifi-raspberry-pi/
