Budget (including currency): $700 - $800
Country: US
Games, programs or workloads that it will be used for: RDR2, Fallout, Battlefield, Minecraft with shaders, Spotify.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 1080p 60fps
Hey guys! So it’s my first time building a pc. I’ve been doing research as much as I can for the past few nights and found some parts.
 Now I’m looking to run these games on med-high settings with great performance. I’m probably going to game daily for a couple hours as well.
 I’m not planning on uploading videos or streaming on Twitch/YouTube.
Also I’m planning on getting the whole set up by maybe next year around this time... since I’m saving up. If I’m lucky maybe by the summer lol.
I would very much appreciate any feedback on the parts I’ve selected!
CPU AMD Ryzen 5 3600 3.6 GHz 6-Core Proccesor
COOLER : ARCTIC Freezer 34 CPU Cooler
Motherboard : MSI B450 TOMAHAWK MAX ATX AM4
MEMORY : G.Skill Ripjaws V 16GB 2 x 8 GB DDR4-3600 CL16
STORAGE : Seagate Barracuda Compute 2TB 3.5 7200RPM
GPU : MSI GeForce GTX 1660 Super 6GB Ventus XS OC
CASE: Corsair 4000D AirFlow ATX
PSU : Corsair TXM Gold 550 W 80+ Gold Semi-Modular ATX
Total : $949
Any recommendations/improvements and reduced cost would be appreciated! Thanks! Sorry if this is too long!
https://linustechtips.com/topic/1280000-first-pc-buildbudget/
First of all, planning one hole year ahead of time seems like a bit too much...I would just wait till you are 1 or 2 months away from purchase time. Specially since prices are not that stable right now, and will probably vary quite a bit from now to one year.
Regarding the build, I would lose the cooler and stick to stock AMD, trade the hard drive for an SSD (at least 500gb, then you can save some more and add the barracuda) and I would probably prefer a lower end B550.
https://linustechtips.com/topic/1280000-first-pc-buildbudget/#findComment-14296011
Thanks for the feedback guys! Aright so I switched to these components...
(Motherboard) - Gigabyte B550M DS3H Micro ATX AM4
(Storage) - Western Digital Blue 500GB M.2-2280 Solid State Drive
Corsair CXM (2015) 450 W 80+ Bronze Certified Semi Modular ATX PSU
and dropped the cooler.
https://linustechtips.com/topic/1280000-first-pc-buildbudget/#findComment-14296495
