Verizon Wireless Latency Problem
Go to solution Solved by Tika,
Update : Fixed the problem by disabling "Adaptive Connectivity" under the network settings.
14 minutes ago, cole0622 said:
use your pc to tether to your phone then on your pc go to network settings>change adapter settings>double click on the adapter for the phone then details, I'm assuming your using windows FYI the phone adapter should say RNDIS somewhere
F@H [] Autobiography []
Main Desktop and Folding Rig :
Cpu : I5-9400f
Gpu : GTX 1070 Founder's Edition
Psu : Seasonic G-650
Ram : G.Skill Aegis 4x8gb DDR4 2666MHz (14-15-15-34)
External Storage : 8tb Western Digital Elements Usb 3.0 Hard Drive
Storage : Samsung 970 Evo 500GB
Motherboard : ASUS B365 Pro-4 m
Gaming Laptop :
Cpu : I7-8750H 2.2ghz
Gpu : GTX 1070 Max Q
Psu : laptop b r i c k
Ram : 16gb 2666Mhz
Storage : 512Gb SATA SSD
Motherboard : it's a laptop.....
old boomer (currently non-functional)
Cpu : I5-6400 2.7ghz (doesn't have a heatsink)
Gpu : Asus RX580 8gb (might sell)
Psu : EVGA 500 watt 80 plus
Ram : 16gb DDR3 1400mhz
Storage : 1tb Toshiba HDD (currently in main pc)
Motherboard : Generic ASUS pre-built motherboard
1 minute ago, cole0622 said:
does the ip match or is similar to the first hop in your previous post?
The only part that's different are the last 3 digits.
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
2 minutes ago, cole0622 said:
ok, what happens if you ping the next hop? if it dosen't have errors do your phone ip with ping IP -n 50 -l 1500
(pinging My Verizon) are these considered "errors"
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
let it finish :
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
ok I think this is a back end issue perhaps DoS protection? every 4th packet has a high time, either the tower or phone is picking up interference and needs to re-transmit the data or there is maintenance on the tower. It could be that your phone is 5g some places are rolling out a band aid kind of operation for 5g users to have a faster connection until the tower can be physically upgraded. I think your going to have to talk to your carrier. Also the phone is new so make sure there are no new updates for it.
It is completely updated and I experienced the problem using the same sim in my old phone. As well I live in the middle of nowhere where I doubt they would think of giving 5G. Is there some sort of work around that you know of?
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
yeah that's where the band aid is mostly, if you can find a way to turn off 5g that might help, have you looked to see if others with the same phone also have the same problem as there could be an update in the works. otherwise I think you will have to contact of your carrier
It does not seem like anyone else has had this problem...
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
There is apparently an update so i'll report back when that's done.
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
Cpu : I5-9400f
Gaming Laptop :
Ram : 16gb 2666Mhz
